$58 ALDL Stream Def
turbodig
$58 ALDL Stream Def
Post by turbodig »
I've been playing with an ALDL stream def for the $58 code... It links!
Got a bit of tweaking to do as far as the values displaying right,
but that really shouldn't take too long. Also needs to be re-scaled for
3Bar usage.
I'm quite pleasantly surprised that it links as well as it does... I wrote
some VB code to do ALDL com a while back, and it was a bear to get the
$58 code to shut up long enough to be able to send it a command.
I read the other post about the planned changes... hopefully, it won't
be too tough to port over.
Great product Mark... combined with the AutoProm this will end up being
the "killer app" for tuning ALDL vehicles.
later,
Dig
Thanks! Do you know what ALDL Datastream ID the $58 code uses? I could write up a definition for your really quick.
If you do end up buying an AutoProm, be sure to let me or craig know that you already have a registration key. This will take $30 off the price of the AutoProm.
turbodig
Post by turbodig »
Mangus wrote:Thanks! Do you know what ALDL Datastream ID the $58 code uses? I could write up a definition for your really quick.
Thanks, that'd be great.
The heartbeat ID is $F0.... I'll send you what I have so far via e-mail, it won't
be too far from there. I basically just edited the '730 file to fit.
We do some different stuff, too, in the 3Bar conversions for the SyTy.
I can always beat that to fit. I'm also working up some custom code to
display EGT, so it'll be slick to be able to change the scaling on the
parameters.
later,
Dig
