Sorry I didn't see this sooner. An 86 Vette should be a $32 bin, which is a 16k bin file. I was working on one today, and the OE chip in it was an AANM1736, which is a 16k bin file. It should have been a 27c128 chip which is 16k x 8 bit wide. I'm guessing you were reading them as perhaps a 27c256, which is more common. You would have then ended up with a 32k bin file. Only half of it would have been the actual program, and data. I am using a Moates adapter board, which has a 27sf512 in it. So I have to make the file 64kx8bits to get the file ready to burn properly. Using the stacking tool, which comes with TunerPro. It works very nicely.
