Command string to short
ptal
Post by ptal »
Trying to use Mode 4 command strings on my 16176424 but the program won't allow for long command strings.
eg. F4,62,04,40,40,00,00,00,00,00,00,00,00,00,00,chksum
:shock:
I know it's damn long but there are about 15 of these that I would like to use to send commands to the ECM that aren't usually available through RT.
Any help is appreciated
Phil
Phil -
Wow, this one slipped through, sorry about that. You should be able to fit this string. Have you verified that the command is being saved into the definition via a text editor? It could be just the UI that's limited.
-M
