Using bin, xdf, and adx from Decipha to datalog my CDAN4/LLX3 96 Cobra. Had issues initially of the values maxxing out. I removed Quarterhorse and reflowed solder into J3 port to ensure connection was solid. Once I reinserted it worked great! Did a datalog and went about my day. Got an updated .bin to which I loaded and went to datalog but it stopped working. Maxed values in dashboard. Reverted to previous bin, did a flash -> verify -> download bin -> flash -> verify -> datalog but same result. Have absolutely no idea what happened and I've tried cleaning port + QH pins with iso under a microscope and no fix.
It will datalog with BinaryEditor just fine. I've cleared banks / RAM prior to flashing with TunerPro just in case BE was messing with it. Removed QH battery for 5 minutes then went straight to flashing. Nothing's working. So what can be done to troubleshoot?
Troubleshooting datalogging w/ Quarterhorse issues?
tyler.h117
