Benelli TRK702 Bosch MSE6.0 TunerPro XDF
Benelli TRK 702 with engine control unit Bosch MSE6.0 now supported by TunerPro tuning software.
Price for XDF definition file: 60 euro.
Tunable engine maps:
- Fuel: nominal lambda for component protection, lambda at WOT, target lambda at partial load, lambda during warm up by engine and coolant temperature, lambda limit for combustion, injection correction factor by effective injection time.
- Ignition: ignition advance-angle characteristic map, optimal ignition advance-angle map, ignition advance-angle correction by engine and coolant temperature.
- Idle: idle engine speed by engine temperature.
- Throttle: standardized air mass flow through throttle valve, desired throttle angle, throttle position sensor.
- Temperature: calculated exhaust gas temperature.
- Air Calculation: volumetric efficiency, map for calculation of nominal charge.
- RPM Limiter.
- Lambda deactivation.
Post: https://oldskulltuning.com/bosch-mse6-0 ... and-bikes/
