Salva qualcuno sa dirmi come si aumenta la grandezza delle tabelle? Perché le caselle sono molto piccole e rimane difficile selezionarle mentre si viaggia. Grazie per la risposta
Save Can anyone tell me how to increase the size of the tables? Because the boxes are very small and it remains difficult to select them while traveling.
Thanks for the answer
table dimensions. Dimensioni tabella e celle
Re: table dimensions. Dimensioni tabella e celle
The actual tables or the cells in the table?
The table can be sized using the drag point in the bottom right of the table window. The cells cannot be resized and are dependant on the setting of your screen display.
