E92 shenanigans
Jim Blackwood
E92 shenanigans
Post by Jim Blackwood »
You will probably think this is weird.
I want to set up a 12704477 ecu to run port injectors. It's a DI controller but I figure the drivers will probably handle them ok? What do you guys think? OK it's just assumed the settings will be borked. I'm willing to work with that. What I'm mostly concerned about is the injector drivers, will they handle the current, and will the waveform they output be acceptable for driving the port injectors?
Jim
