Tunerpro not recognizing XDF file ALH ECU
PrecisionTDI
Post by PrecisionTDI »
Hey everyone,
I’ve been working on tuning my ALH TDI (038906012M ECU) and I’m running into a frustrating issue with TunerPro. I’ve followed all the steps to load a .bin file and its corresponding .xdf map file, but TunerPro keeps saying “No XDF selected” and nothing shows up in the left panel.
Here’s what I’ve tried so far:
• Reinstalled TunerPro multiple times (both 64-bit and legacy versions).
• Ensured the .xdf file is saved as ANSI encoding (not UTF-8).
• Renamed the file to .xdf and double-checked the extension (not .txt).
• Used a fresh stock ALH .bin file and even created a simple test .xdf file.
• Tried running TunerPro as administrator.
Even after all this, TunerPro still won’t load the .xdf properly and nothing shows up in the tables. Is there anything I’m missing or anything else I can try? Maybe there’s a specific setting or file structure I’m overlooking?
Any help would be much appreciated!
Thanks in advance for your time!
