opening table views from the same address and make a modifycation on a table should be updated as well on the another view without save/reopen the windows.
tables as example: open id_maf_tab__v_maf AND id_maf_tab__v_maf_1__v_maf_2.
(as a new user of this app this missig feature made me a confused a little )
It is difficult for me to understand what you are describing, but if you have two XDF items open that reference the same address, changing one should indeed update the other already, or prompt the user before refreshing if the other has also been modified.
If you have an example of where this is not working, please email me the bin, XDF, and instructions on how to reproduce the issue.
Thank you for sending the video. The change you make in an editor is not committed to the bin until you hit the save button in the editor. As stated, you will then be prompted to update the other window with the new contents. Your video shows this happening has expected.
