maf table scalars problemo
mdelano7
Post by mdelano7 »
Hey, tunerpro is awesome! and the interface is wicked good.
One problem though that i think might be a bug. I am using windows xp, your 6e ecu file and arap bin. version 3.05 of tunerpro
When i change the maf table scalars, the actual table data does not recalculate, the data stays as if the scalars were stock.
the ecu format doesn't allow for "scaling one item based on another". This isn't a tunerpro limitation, but a limitation of the file format it uses (public domain = I didnt write it).
You don't typically need to deal with the scalars.
