A question about ALDL Monitors in TunerPro RT
KrazyKaycee
Post by KrazyKaycee »
Is there a setting that triggers the ALDL Monitor screen to show the white line progressing and turn them on and off? I noticed messing around with a couple of definitions that some did do that and some didnt. When it didnt it just showed the actual value of the bit in red in the upper right corner and it changed with each sample so data was getting read properly just no line to show the value at each sample time.
Hope that made sense :)
kaycee
Make sure the min/max is set correctly for the item within the definition, as this defines the range that the scope displays.
