Boosted NW Chip Burner no longer detected by TunerPro
It appears a recent firmware update for the Boosted NW Chip Burner has moved its version outside the range TunerPro expects, so it no longer detects the hardware as a Moates Burn 2. Any chance of modifying the allowed firmware version in the future to allow TunerPro to detect it again?
Thank you!
- 1987 Corvette - modified to 315 rwhp
- 1994 Corvette ZR-1 - modified to 445 rwhp
- 2015 Corvette Z06 - stock
Re: Boosted NW Chip Burner no longer detected by TunerPro
They should fix their firmware, as I believe the fix on the TunerPro side wouldn't be fair to other manufacturers.
Yes this is unfortunate. We can reflash your unit if you absolutely must burn in tunerpro and can't use the provided software.scorp508 wrote: ↑Tue May 28, 2024 7:03 am It appears a recent firmware update for the Boosted NW Chip Burner has moved its version outside the range TunerPro expects, so it no longer detects the hardware as a Moates Burn 2. Any chance of modifying the allowed firmware version in the future to allow TunerPro to detect it again?Thank you!
