Boosted NW Chip Burner no longer detected by TunerPro
scorp508
Post by scorp508 »
It appears a recent firmware update for the Boosted NW Chip Burner has moved its version outside the range TunerPro expects, so it no longer detects the hardware as a Moates Burn 2. Any chance of modifying the allowed firmware version in the future to allow TunerPro to detect it again? :) Thank you!
  • 1987 Corvette - modified to 315 rwhp
  • 1994 Corvette ZR-1 - modified to 445 rwhp
  • 2015 Corvette Z06 - stock
Re: Boosted NW Chip Burner no longer detected by TunerPro
They should fix their firmware, as I believe the fix on the TunerPro side wouldn't be fair to other manufacturers.
jlowens76
Post by jlowens76 »
scorp508 wrote: Tue May 28, 2024 7:03 am It appears a recent firmware update for the Boosted NW Chip Burner has moved its version outside the range TunerPro expects, so it no longer detects the hardware as a Moates Burn 2. Any chance of modifying the allowed firmware version in the future to allow TunerPro to detect it again? :) Thank you!
Yes this is unfortunate. We can reflash your unit if you absolutely must burn in tunerpro and can't use the provided software.
