HAVING A PROBLEM WITH READING MY MEMCAL . DO I PUT THE
BUFFER START AT 0
DEVICE START AT 0
END BUFFER AT 7FFF ???
ALL I GET IS JUNK WHEN USING 8D MASK WHICH I IMPORTED FROM
THE ECU FILE. WHAT AM I DOING WRONG THANKS.
NOTE: THE EPROM HAS A LABLE ON IT WHICH SAYS DELCO 5224
92 CORVETTE MEMCAL
000000 -> 007FFF is the correct setting for the $8D.
it is a 32K bin file.
Here are all the offset types and details
http://www.moates.net/documentation.php ... tion_id=75
Be sure the chip is not backwards in the reader.
JOHN QUINTUS
THANKS FOR YOUR REPLY, THIS IS MY PROBLEM-- I HAVE READ THE
MEMCAL STARTING AT "0" AND GET A CHECK SUM OF E6B0
SAVED FILE SIZE OF 8000
WHEN VIEWING THE HEX CODE THIER IS DATA FROM- 0 HEX TO EE4 THEN DATA PICKS UP AGIAN AT
2000 THRU 7D0B THEN
ZERO'S TO 7FA0 THEN DATA TO END 7FFF
I DON'T KNOW IF THIS CORRECT OR IS MY MASK NOT RIGHT
THIS ALL FOR 92 CORVETTE THANKS FOR YOUR HELP.
2000 THRU 7D0B THEN
JOHN QUINTUS
