Topkick 7.0 litre adx file
rickricca
Post by rickricca »
Looking for adx file to work with 1998 topkick 7.0 litre (160 baud)
I can't find consistent info on what ECM is in that. Is it a 16196388?
rickricca
Post by rickricca »
Mangus wrote:I can't find consistent info on what ECM is in that. Is it a 16196388?
Yes it is!
How did you find that number?
Search terms:
1998 topkick ECM
Unfortunately there's very little information on this ECM. If it is truly 160 baud, then you can probably start with one of the existing 160 baud definitions. There tends to be either 20-byte or 25-byte packets, and the locations of the main data points (RPM, etc) don't move around much.
A little experimentation may yield useful results.
rickricca
Post by rickricca »
Thanks for getting back to me
GM did a bad thing here. The only system that used the heavy truck protocol is the ABS system, the plug is the OBD 2 style, and the factory manual states that the ECU communicates 160 baud. Took quite a bit of research and a bit of money spent to even get this far..
I was going to try one of the large gm v8 160 baud files, so thanks for the encouragement
R
Mangus wrote:Search terms:
1998 topkick ECM
rickricca
Post by rickricca »
The file from a 1990 7.4 tbi seems to work
rickricca wrote:Thanks for getting back to me
R
1998 topkick ECM
most of the 160 baud TBI V8 datastreams are so very similar, i'm not surprised.
