I need help to get my 1992 Camaro tune.
Here is my setup:
1992 Camaro RS.50mm TBI /350 5.7 fuel injectors/350 Engine bored 60 over /1997 Camaro LT1 Camshaft /6 speed T56 Manual Transmission/
I need help to find a tune chip for my setup and can not find anything close to my setup. I would like any info on a chip or even help to find someone to burn a chip or even a burner machine. I appreciate anyone suggestions or guidance.
Help needed for my 1992 Camaro Tune
Re: Help needed for my 1992 Camaro Tune
I would contact Tunedperformance on www.thirdgen.org.
_____________________________
1971 Pro-Touring Camaro
GM HT383 shortblock, MiniRam manifold, AFR heads,"8-speed" transmission (700R4 + Gear Vendors OD)
Self-Tuned 7730 ECM
PM me about tuning your 7730 ECM
Self-Tuned 7730 ECM
Probably better to just contact Tuned Performance at tunedperformance "dot" org. Deal with the members of TGO and you get answers that just go all over the place. You may end up thinking you need a Johnson Rod.
For your 1992 Camaro RS setup, consider reaching out to tuning specialists or performance shops that have experience with older GM vehicles; they may have custom chip tuning options available. Websites like LT1Swap.com or thirdgen.org are great resources for finding specific tuning chips and advice tailored to your setup. You can also check for standalone tuning solutions like the Megasquirt system, which allows for more customization. Additionally, look for a local performance shop equipped with a chip burner or a tuner who can create a custom tune for your engine.
